Does anyone have a great solution for hooking up their PCV system to a Kenne Bell supercharger? I'm pullied for 14.5 psi and currently using a plastic fuel filter between the PCV in the rear of the intake (stock location) and the elbow feeding the supercharger. While this seems to work, it also seems that using something more appropriate like an oil/air separator with a drainback would be a better idea.
Also, at this pressure ratio I get a significant amount of oil loss from the OEM vent on the blower snout. It looks like its a part ordered off of McMaster-Carr and I found one that should control the mess a bit better: https://www.mcmaster.com/#8631t11/=15qqbbc
