Need to do my throw out bearing and figured I would do the clutch at the same time. Anyone know the part number?
Thanks.
Are you sure you want to go back with the stock clutch? My opinion is that you could get a better clutch for less money from the aftermarket.
Just a thought.
Item Part Number Description
1 6375 Flywheel
2 6397 Flywheel to clutch pressure plate dowel (3 req'd)
3 7600 Pilot bearing
4 7550 Clutch disc
5 7563 Clutch pressure plate
6 7515 Clutch release lever
7 7B602 Clutch release lever stud
8 N606063-S2 Bolt (6 req'd)
9 6392 Flywheel housing
10 55981-S36M Bolt
11 7513 Clutch release lever dust shield
12 7548 Clutch release hub and bearing
14 N602549-S100 Bolt (6 req'd) 4.6L (2V)
14 N808969-S100 Bolt (6 req'd) 4.6L (4V)
15 — Rear face of block and flywheel (part of 6010)
16 — Bolt (3 req'd)
17 6397 Flywheel housing to block dowel (2 req'd)
These part #'s are out of the service manual, but they don't look like traditional ford parts. I'm sure a parts counter can help you figure out what these mean.
Just a thought.
1 6375 Flywheel
4 7550 Clutch disc
10 55981-S36M Bolt
16 — Bolt (3 req'd)
Hey thanks for the excellent help! Much appreciated. Guess I'll look around for clutch suggestions, but I don't plan on putting a ton of HP through the car and didn't want to increase the clutch 'effort' with daily driving. Wife uses the car nearly as much as I do.
