Hello Stang plus2 birds, I was wondering what you needed to do on your ebrake setup to get it to work with your m2300k kit? Would it be possible just to remove the threaded rod with the hook on the end of it, and install the M2810-A short middle cable from the M2300-k kit? Let me know how you accomplished this as I am currently stuck on this part.
thanks,
Chris
Discussion Starter #2
TTT
What year car are you talking about? Your 85?
I forget, won't the stock setup work fine for the ebrake? It's just that you'd have to adjust it from the inside like you had to do before. I made my one custom rod and hook so that I could adjust it from under the car. But, I *think* I used the same equalizer. If not, I got one from an '87.
