What's your timing set up and how about the auir/fuel ratio?
What's the RWHP with your timing and air fuel ratio?
Do you think I can use STEEDA timing adjuster with the supercharger?
Thanks in Advance.
Cant give you specifics of A/F or timing, but I can tell you know its makin close to 340rwhp with a "safe" tune on 98 heads.
I use my timing adjuster with it. I keep it set at 10degrees (stock initial) as the dyno tuned chip takes care of the rest of the timing, but I use it to advance the base timing when running a higher octane or running under better conditions. Great to be able to experiement with it, just do it slowly and back off if you sense any detonation.
