Excellent thread. I've almost solved a ten year problem. Car is a 66' mustang with an EFI 5.0 w/an AOD out of an 89 foxbody. Many years ago I got a harness that was told it was out of a 90' 5.0 AOD stang. It has the light blue jumper wire along the bottom row of pins.
I also purchased an ecu from someone at the time who told me it was out of a stang, years ago I had no idea I needed an A9P. After pulling the ecu which I had buried up inside the dash, to my amazement it was not an A9P, it was a truck ecu! The car always ran rich, idled sloppy, I tried many things over the years.
I just pulled the ecu and did a test of pin 46 during crank and there is zero voltage. I'm going to get an A9P ecu. HERE IS MY QUESTION:
Upon inspecting the wiring and the light blue looped wire, the opposing connector has NO wires in either pin location, meaning, the looped wire is doing nothing. I do not see anywhere where this harness has been cut or modified at all. I'm going to track down a diagram but has anyone seen this? Wires missing in those pin locations?
