I have been getting tons of pms about this so I figured its time to make a post about it. Yes the Oxygen sensor harness has changed alteast 4 times that I know of and it can cause issues such as frying the trace off pin46 on manual ECU's or leaving you unable to pull codes in KOER if interchanged. The looped jumper wire for the NDS where it connects to the main harness is the difference. I have three o2 sensors harnesses here to show this but I need to confirm 2 of the harness years/ tranmissions since they got mixed up in a spare parts box. One of these is from a 91 5spd and the other I can't remember what I pulled it out of. I need to figure out which one is which first but I'll update it later when I do
If anyone has a factory aod or t5 87-93 mustang and can take a few pics of this harness it would be pretty helpfull, just list the year and transmission with a picture showing the pin location of the looped wire. The conector is located directly under where the factory mass air meter is mounted. Any way heres the pics of the ones I have just to show the differences.
90 aod harness
EDIT the one below with the purple/ yellow stripped looped wire is from a factory 1990 5spd car.
The blue / yellow stripped jumper wire matches the 02 harness in my 93 gt 5spd car
This is out of a 90 factory 5spd car so this does confirm NOT ALL 5spd harnesses are the same. I checked two friends cars that are both factory 1990 5spds.
90 aod harness
