1 - 8 of 8 Posts
Can someone tell me where it is located on my 92 GT??:confused:
TIA
Banned
right next to the kanuuten valve above the muffler berrings :)
Seriously tho, i have no idea what an orriface tube is. Why are you lookin for it?
Are you maybe thinking of the smog (thermactor crossover tube) that runs along the back of the motor attached to the heads?
It is a filter that goes with the air conditioning.I'm thinking its located in one of the lines.:confused:
I've been told I would have to replace the entire line.?? :confused:
Seriously there is an orfice tube on your car. Like stated it is in the a/c system in the low side line running into the evaporator usually.Hmm I haven't had to replace mine but most of the ones I have seen are replacable seperate. The accumulator usually needs the line replaced with it.
ranger7ltr said:
It's in the line BELOW the accumulator that attaches to the evaporator...Some Fords have a crimp in that line so you have to replace the entire line...It depends on the year.....
We have a winner! It goes from condenser to evaporator at the passenger side of underhood.
The Liquid Line with Orifice can be had from any Ford dealer for ~$20.
Discussion Starter · #7 ·
Part#??
Thanks....can you provide a part # for 92 GT??
1 - 8 of 8 Posts
