i just did the headswap but i have no manifolds on my car. i am going to install my hooker longtubes tomorrow, but i was just wanting to know if i can start it up for just like 5 seconds to see if it will run thanks
You Could Mess up A valve Or Seal Or Something If ya Let it Run for Too Long, But I Cant See Just Starting It Up For a Sec Doing Damage, Just dont Go Driving Around Like That :D
Discussion Starter · #5 ·
i ended up starting it up. after a couple minutes of chugging it started right up. LOUD AS A ****. that is and understatement, i dunno if it was so loud idlying because of the cams or what but it was loud. I shut it off after about 5 seconds, and did it again about 5 minutues later and it did the same thing and i shut it off again. it turned out that i spewed gas everywhere in my engine because i was missing and enjector o-rings but then i was also leaking some oil. i didnt have my dispstick tube in, so do you think that could be the cause?
What Part of The Motor was Covered In oil?
Did you Transfer the Oil Plugs Over To The New Heads?
Good Luck,
~Veech~
