For all of you with Nitrous wet kits and electric fuel pressure gauges, what are yall using to connect both the fuel pressure gauge sender and the N2o fuel line to the shrader valve on the fuel rail? Is there some type of adapter?
Anything will help.
Well if you are running a adj fuel regulator there is usually a port blocked off where you can hook up your fuel gage. Then run the fuel to the N2O kit off the rail. This is how i did it...
i just use a 1/8" NPT T, theres many ways to plumb it up depending on what fittings you have available to you
