I bought a set of 185s used, and think I should have them milled. Compression ratio will then go up, right? It is a street car, so when i do a stroker, will my CR be too high? What if I use flat top pistons? I think I'll probably need dished pistons to keep the CR down to about 10.5 to 1 for street use on pump gas. Is my thinking correct? Thanks-Dan
