I'm still not sure we have the K-member set right,
we got the engine and tranny put together, put the Pass side header on , out side the car, glad we did, it fit well , but looks like it would have been real hard to do after the engine was in.
also put the starter and the main 1/0 engine ground for the Battery relocate to the rear.
Pro-M wants a ground from the battery to the engine, so I'll do it that way.
one problem we had was lining up the motor mount studs with the slots in the K-member.
I hope we didn't mess up anything, but we used a strap, to pull the transmission side ways , enough to get the drivers side stud in the slot, ( had to pull it to the pass. side of the car about an inch?? ). but we had to pull it pretty hard.
I hope we didn't tear up anything, none of this stuff is cheap, T-56 , Dart 427,,,
we had to adjust the tranny mount just a little, to get the driveshaft and shifter centered looking in the tunnel, and shifter hole.
