I'm completely rebuilding my mustang and am planning on installing through-the-floor subs. Is it ok to do this with everything (I mean everything) out of the car or should it have all the running gear in it including the engine, tranny, kmember, rear.... ? Same question about welding up the torque boxes, ok to do now?
Anything else you would recommend I do while I have everything completely apart?
Thanks!
Actually,
That is the best time to do it. Make sure you have it leveled in both directions on your jackstands. This is to make sure that it is still square after you weld the connectors back in.
