1 - 10 of 10 Posts
Who has modmax springs in their motor?
What cams are you running(lift,duration,etc..)?
How many miles do you have on them?
Is your car an auto or manual?
How many rpms are you spinning to before shifts?
Stock or bronze guides?
When did you purchase them?
Have you broken any springs?
If so...intake or exhaust?
JL
Do you want some Springs???
I have some FOMPK Springs that are similiar to ModMax but a little stiffer!
JOEL
Who has modmax springs in their motor? Me
What cams are you running(lift,duration,etc..)? Comp Cams @ .550 lift
How many miles do you have on them? 3-4,000
Is your car an auto or manual? Manual
How many rpms are you spinning to before shifts? About 6200rpm
Stock or bronze guides? Bronze
When did you purchase them? Purchased in Oct 2002 and installed by Fox Lake
Have you broken any springs? No
If so...intake or exhaust? NA
What cams are you running(lift,duration,etc..)? Comp .550 234/238
How many miles do you have on them? 500
Is your car an auto or manual? manual
How many rpms are you spinning to before shifts? up to 6500 but usually 6300
Stock or bronze guides? stock
When did you purchase them? not sure, through DTA probably April
What cams are you running(lift,duration,etc..)? Crane regrinds (.548"/.522", 217/219 @ .050", 114 LSA), soon to have Comp billets installed.
How many miles do you have on them? Probably 1,500
How many rpms are you spinning to before shifts? Usually 6300 RPM, but I've tapped the 6500 RPM rev limiter a few times.
Stock or bronze guides?stock, we did replace the valve stem seals, however, with FelPro's.
When did you purchase them? Spring 2001
Have you broken any springs? no
The cam specs are in my sig. I broke them a few times, both ex and intake, did'nt matter.
Bottom line, get the comp/crower beehive springs.
BTW, I don't have a problem with modmax, I have bought lots of parts from them (but no more springs) :)
Bob
What cams are you running(lift,duration,etc..)? Stock 2001 cams
How many miles do you have on them? 1500
How many rpms are you spinning to before shifts? About 5500rpm
Stock or bronze guides?Stock
When did you purchase them? Purchased in Oct 2002 and installed by Steen Racing
Bob
I agree the Modmax springs are suspect when you put power through them. Right before I sold my car, I broke a Mod Max spring. They were less than a year old and were quite noisy. People that have not broken them yet haven't put any boost behind them probably. What an expensive repair to add to the loss I took on the sale. This was also with stock cams. We replaced them with FompK springs and I believe the kid that bought the car broke another valvespring 2-3 days after he picked it up.
1 - 10 of 10 Posts
