87 5.0 119k... Now that it has got cold out here in Cincy, the oil light is coming on when the car is cold from over night or when having sat for a bit in 40 degree weather. Oil level is fine. When you start it the light is on for a a min if not less. Once the car runs for that little bit if not just 10 seconds or so the light will flicker a tiny bit and go out. If you good it a little it may go out sooner. The same time the needle gauge stays up where it should be, moving as you goose it. The car does use oil, a quart a MONTH maybe. No burning, no leaking, bottom of motor/car is clean.
Could I be lucky and the sensor for the light is just bad in doing its job when cold or do I have an oil pressure issue when cold. The car never makes any chatter from the motor as if it were starving for oil.
I do plan to change out the oil sensors soon.
