Thought i was gonna be able to start it this weekend but primed the oil pump and like a 1-2 quarts practicly shot out the back of the motor. It is a canton pan, and the guy who put the shortblock together put a felpro pan gasket on. Its rubber with a metal frame in it that runs front to back. Whats going on here? Any help ??
Pat
I would check the block not the pan. I bet a oil pug got left out when you had it rebuilt. If the pan leaks, it would do it when the engine is running and oil is being thrown around.
did you put in the rear main seal. I know someone who didn't.
