1 - 1 of 1 Posts
the other day i put a pcv valve on and inadvertently kinked the hosed running from it. I didnt notice till i found out i had an oil leak two days later (oil puddling up around distributer and under water neck). anyway i cant figure where i blew the gasket; at the lower intake or the timing chain cover. where would be more likely to blow in a high crankcase pressure situation. thanks for any help.
1 - 1 of 1 Posts
