Status
Not open for further replies.
Looking for a set (2 piece) of the OEM oil pan rail supports. This external part sits under the pan bolts and helps provide even pressure on the oil pan rail. Was found on at the least the 86-93 5.0's but probably was use prior to 86 and up to the 95's. Not sure what the offical name for this part is but I think you guys will know what it is. shipped to 02910. Thanks. Steve
BOUGHT! NO LONGER NEEDED!
I just pulled apart my 86 motor last week and there was nothing like that on mine.
Oh no? Thanks for the update, for some reason I thought they had started coming thru in the 80's, perhaps it wasn't until the early 90's. I have confirmed 93-95's for sure. Thanks again.
Discussion Starter · #6 ·
Status
