If I swap a PCM on a 2004 Mustang GT will the mileage on the odometer change to the mileage of the car from the donor PCM?
I swapped gauges on a 1999 and the odometer swapped with it I know when you have the gauges rebuilt they need to odometer readings so they can set it
The mileage is stored in the odometer board in the cluster. Also the cluster PATS too. So no the mileage will stay the same, you will need to have PATS turned off in your tune though since the computer PATS and cluster PATS will not match anymore.
