1 - 1 of 1 Posts
Not necessarily a Q or complaint, but who's thinking was this?
I'm creating a custom mounting plate and so far everything's lining up (pulley, front and back sides), but to get the 6th bolt in (novi/vortech),: the oil inlet nozzle blocks any way a plate can be fitted between the 5th & 6th bolts. I know in some vortech kits they only use 5 bolts and/or their sn95 kit uses an extra rod (which doesn't help much for flex). Why did vortech do that (put the nozzle fitting to interfere with the mounting plate)?
Note: Novi 1500 race unit, that plate is a laser cut paper template I'm using to confirm alignment/fitment that works with the current xb1a setup.
1 - 1 of 1 Posts
