Hey all, new to the Nitrous scene, just purchased a Super Pro Shot carb plate setup. It came with 190-350 Shot jets. I'm running it on a mostly stock 1985 Mustang 5.0 H.O roller motor. I want to operate between 75-150 shot. I'm wondering what size jets I need, and also a little help on how the setup works. If it helps the P/N on the N2O selinoid is 16045, and the P/N on the Fuel Cheater selinoid is 16050. Can try and get pictures if necessary. Thanks for any and all help!
Nitrous Oxide fuel Jet size and HP Calculator nos n2o
You can use the calc. or even better scroll down to the very bottom of the page.
There is a nice chart that gives approximate h.p. per jet.
Set the flowing fuel pressure (.073 jet) to about 6.5 lb.
In the blazing heat of summer I use a 10 jet spread. When the temps cool off (now)
I use a 8/9 spread. A .044 nitrous jet is 75 hp,try a .035 or .036 fuel jet.
Beyond 100 I would use a NGK non projected plug. Use the NOS timing chart.
