1 - 1 of 1 Posts
Was accidentally sent the wrong set of brake brackets and can’t use them.
These are for old style ford 9” ends using sn95 rear brakes. This does not include the hardware or caliper spacer as I’m using that with the brackets. Spacer would not be hard to make at all and I can sent pics of it if need be.
I did cut these to slide over the axle vs removing axle, destroy new bearings and press new bearings on. This has zero effect on them and still has all the backing plate tabs if your wanting to run a dust plate/backing plate
$110 shipped
1056813
1 - 1 of 1 Posts
