· Registered
I am finishing up the mass air conversion on my 88, all wires done except the jumper from pin 19 of the ecu to the fuel pump relay. My car does not have a wire in the 19 location so what should I do about that? I did not relocate the pins for the air pump/these directions because I don't have any air pump, should they be moved anyway?
Following these directions
Converting 88 to MAF from 92 car | StangNet
· Registered
You have to add the pin and wire. It’s not existing. Some of the mass air conversion kits come with three additional wires. Two tap into the VSS to pin 3 and 6 and the other goes into pin 19 and connects to the pink wire on the fuel pump relay under the seat.
  • Like
Reactions: Jmo1999
