I have spent the past few months rebuilding my 302. I finally got it to run but my oil pressure gauge read 0. At first thought it was the guage so I replaced sender and guage cluster, still nothing. Today I put a mechanical gauge on and primed the oil pump with a drill (counterclockwise) and still no oil pressure. I looked with a scope camera down the distributor hole and could see that the pump shaft was engaged and turning in the pump. I also noticed that if I switched the drill to clockwise I could hear the pump blowing air and could hear the oil do a pretty loud bubbling. I’m confused as to why the pump does not seem to pump any but does seem to blow air in the opposite direction. Any ideas would be greatly appreciated.
Also, I have run the engine a few times because I thought I had oil pressure but I now know I did not (I know this is a big mess up) I had found metal shavings on the dip stick but they were magnetic, so I was under the impression that was fine with a fresh engine on initial start. BUT today I noticed some large metal shaving stuck to the distributor drive gear, and they were NOT magnetic. How bad is that and do you think the bottom end is junk or if I get the oil pump working will I be okay? A little nervous about having months of work ruined
thanks
Jacob
thanks
Jacob
