i have an 86 H.O. new short block from ford motor racing 351 windsor heads trick flow upper and lower intake all new . my question is car runs but doesnt idle also spark plugs are slightly black like too much fuel any suggestions will be great its spring i wanna get on the road so thanx in advance
no i havent checked my codes but i have a coolant tempature sensor thats broken not sure if that effects anything or not.i dont have a computer to check my codes
I would check your firing order, make sure all your plugs are connected good, and make sure your maf sensor is connected. If that doesn't work check your fuel pressure.
Get yourself a new ECT. Without one the car can't go into closed loop and must run the fuel ratio from tables. It errs on the rich side for safety. Hence your blackened plugs.
Discussion Starter · #6 ·
thanx 90lxcp for the advice i put the new ect in but still no idle someone told me have to reset computer but not sure how to do that anymore suggestions thanx again
