hey,anybody has advise on nitrous? if you have 30 lbs injector and mass air meter to match with a ajustable regulator with stock intake. and want to put gas on it 150 shot . what size fuel pump do i need ? keep in mind this is a every weekend car .
My opinion is the minimum you would want if you're going to upgrade the pump is the 190 lph, but if your going to spend the money you might as well buy the 255 high pressure pump. That way you have some room to grow in the future.
Before I added all my mods, my stock pump went out and I replaced it with the 255 high pressure pump and it has worked great since!
