the nitride 8-rib vortech 7" pulley is around 85$ and the blk aluminum one is around 115$. which one should I buy. what is the difference?
The aluminum is lighter and takes less power to spin. The difference in weight is only about 2lbs, but when you spin that to 6000RPMs it makes a big difference. Angular acceleration is a=V^2/r and F=m*a assume angular acceleration is the same for both the nitride pulley will put twice the force on the crank. That probably only translates to a few hp but every little bit helps.
Axistang-where did you find those pulleys that cheap?? Are you talking about the ASP pulleys?
