Hey everyone I am new to this forum and I have been debating on what route I should go with for my engine build. I have a 2003 Ford Mustang GT.
Background: I have been having exhaust smoke issues, come to find out I have low compression in cylinder 4. I had dripped some oil down only to find that it did seal. Bad Rings :(
I desired a quick and fun street car that may see some track time.
My goal is to put an On3 turbo system into my car.
Do I buy a salvage yard engine and turbo that setup?
Do I build up and engine with a forged rotating assembly?
I am not confident in a stock motor to take the beating of a turbo set up even though I have a friend that is running an On3 on his SN95 stock motor @ 10psi and has like 10k miles on it.
Building an engine costs a lot of money and Im not rich. But I have found some forged rotating assemblies on MMR and they seem to be decent parts.
I am just looking for some guidance as what works best and some opinions from those who have traveled this road before.
Thanks!
Racing is expensive, how fast do you want to go? I personally would rebuild what you have, if you've got the know how. You could get a salvage yard engine only to find out that the previous owner changed the oil twice in its 180,000 miles. Besides the engine rebuild, and the turbo kit, there's a lot of other expenses to consider. Injectors, tuning devices, air filter, fuel pump, fuel lines, pressure regulator, and so on. Just do some homework and have a goal in mind, and stick with it.
Building an engine costs a lot of money and Im not rich. !
Define "not rich" and we will go from there. ( AKA, what is your budget?)
Since you're set on actually making power with boost I wouldn't do a stock motor unless the funds aren't there to up the ante a bit. From what I've read the stock rods are the weak link so you may be able to put aftermarket rods in a stock motor to gain some reliability but the best option is to build/buy a engine with good components. Knowing how much power you want and how much $$ you want to spend would help.
ks
^^^^What Kevin said. Spend a little money now and then you don't have to worry as much. I just rebuilt my 03 2V out of necessity because I didn't replace the timing chain tensioners when I had the chance. FWIW, I bought a cobra crank off of ebay for $500, I got MMR forged rods for $300 and I won an auction on ebay for a set of NIB JE cobra pistons for $200. I would advise you to get better rods like Manley. My builder said the MMR rods are not terrible but they needed work so I ended up paying the same amount anyway. Oh, and upgrade to the iron tensioners and a cobra oil pump and ARP fasteners. This short block combo should reliably support 700-800 RWHP. Also, FWIW again, this is my first turbo build, too and the learning curve is huge. It's much more complex than a supercharger, IMO. But when you finally get it sorted out, it's pretty awesome.
If you're interested, I have an On3 67mm unit with the billet wheel and ceramic ball bearing upgrade.
