1 - 12 of 12 Posts
I have a 91' gt and am planning to put some twisted wedge heads and a tfs stage 1 cam in it. While i'm at it, would you guys recommend swapping in some new lifters and a new timing chain set? Would the stock ones be worn out to where they should be replaced? My engine has 135,000 miles on it. If so, what lifters and timing chain set would you guys recommend? I don't mind spending the money if it is recommended, but I also wouldn't mind keeping that extra money in my pocket if the stock parts would work perfectly fine. Any input is appreciated.
yes replace them. FMS makes lifters for $120 and the FMS 9 keyway timing set is like $70. get both and dont worry about it
take care,
adam
I second the recommendation: you can't beat the quality for the money of the Ford Racing roller lifters and multi-keyway timing set.
Steve A.
3rd it here - used those exact parts in mine - wonderful stuff.
whats the best place to order these parts. I need a chain, headgaskets,bolts, ect.
Not sure there's one 'best place' Dan. Since you're in FL, I'd contact Dave at JD's Performance. They seem to have a great rep among the customers they serve, and they've helped me in the past. They're in Orlando.
http://www.jdsperformance.com/
take care,
adam
I thought the oem hyd. roller lifters were like 250...do you know where I can find for 120?????
I got mine for $100 from Central Coast Mustang last year - I bought other stuff too, and that may have impacted the price I was able to get on the lifters. Seems to be some chatter as to whether they're still around or not though....
I'm rebuilding too, I'm getting those summit lifters, should I get new pushrods too?
I just ordered new lifters and pushrods from Lonestar Performance. Lifters were $109 and pushrods were $50. I've dealt with LSP twice and had good service both times...I recommend them. Of course you can't go wrong with Summit, either.
if anyone needs...i have the 9 point index timing chain and the lifters...email me at [email protected]...low miles on them
1 - 12 of 12 Posts
