· Registered
So i went to the dyno this weekend and maxxed out my focus svt pump. Now i have decided to go return style and all my parts will be here tomorrow and i need to know what i should do with some parts i dont know if i need. anyways can i disable any of these parts and also the emission stuff back at the tank b/c i am also sumping the tank. thanks and here is a few pics of some of the parts. if you need any more info about the car ill answer. Btw it will be getting retuned after the install of the return style. parts are on the drivers side of engine.
Thanks,
Brett
· Registered
Discussion Starter · #4 ·
yeah i have a comp eng sump coming and going to be doing the swap over the next couple days. the parts i am wandering about are up on the drivers side top of the engine. i have an egr delete already but the plug that goes to the sensor on the fuel rail and there is two other sensors that vacuum lines and plugs go into that i was wandering if i could remove, one has a knob you can turn on the top and the other is flat with two vacuum ports . if anyone wants to post their email i can send the pics. i just dont know what the last two go to. thanks,
brett edmonds
· Registered
you can remove the fuel rail pressure sensor. your tuner will have to turn it off though before you start the car. i dont know why you want to tear out the purge valve, it does not take awat power at all. the more crap you start pulling out, the more headache you will have later.
