I picked up a new edge with an On3 (single turbo) kit installed on it and I'm currently replacing the engine. I noticed that the drain line for the turbo is going to the front of the oil pan and the line goes below the oil pan fitting a bit before finally terminating. It looks like PO was attempting to avoid getting interference with the crank pulley. How have you all run your drain lines? I have a spare oil pan and can start over.
Thanks,
Josh
Discussion Starter #2
Is this in the wrong section of the forum? Any forward mount turbo guys that can chime in? I imagine it wouldn't need to be an On3 kit.
Late to the party but if you indeed have the pan off- heres what we did- Jegs 10AN 45 degree towards pass side. It requires a 10AN pan tap which we got off of Amazon for like $15. It has jam nut on backside of drain with teflon seals on both sides.
1057620
1057621
