here goes the new combo,
Paxton Novi 1000 2.75 pulley 8 lbs(so im told)
Edelbrock performer heads 190 160
Edel. Perf. RPM 2 intake
tfs stage 1 cam
pro-m 80mm
36 lb. inj.
70mm tb
and the other bolt ons below
any guesstimates on new e.t.s
streets/slicks
Id say low 12's ... with a sticky tire and a hard launch, then you'll proboly fry that clutch, and run 14's..lol I would suggest a better clutch, like SPEC or Centerforce you'll proboly need it with a sticky tire...and I like the alumin drive shafts as well, much stronger than the factory ones...then you could add more cam, more boost Launch it at 5500, with 4.10's and possibly get into the 11's , hey GL!
2wld4u
