kay so i picked up a set of Windsor Jr. heads and a edelbrock performer intake. I would like to see 300 rwhp out of this setup. I am gonna port these heads pretty good and port the intake some too. The car is a T5 and i will also have long tubes, msd, a/c delete, smog delete, a 125 wet shot(like to break 400 on the bottle) and probably weld wheels all the way around. Does anybody know what a good cam would be for this setup, other than custom grind. I am looking to do a budget build setup.
Is this posibable or should i get a better intake?
What cam should i use?
Thanks!!!
2006 Ford Mustang GT
The Eddy Performer is a good intake. There are better heads than the Windsor Jr but they'll get the job done and 300rwhp is a realistic target. I'd suggest the CompCams XE270HR-14 cam if you still have 1.6 ratio rockers. Just make sure that the valve springs are rated for at least 0.550" of valve lift.
plenty of ots cams u can use
...since u didnt mention cc of the head, compression, gear, goals, budget, piston in use...i assume you are just throwing some stuff together, those are the things i think of when looking for the "perfect cam"
oh and 400rw with a h/c/i mustang with spray is no biggie, you can do it !
Discussion Starter · #4 ·
The heads are 58cc Chamber and i have Probe SRS pistons so my compression ratio will be 9.54. And 3.73 rear gears, i would like to spend less than 200 might try and pick one up off here...
my roommate runs the following setup
stock 302 shortblock
t5 world class
unported windsor jr irons
unported systemax intake
comp nx cam from summit .577/.577(they sell 3 diff ones)
c&l 76mm maf
70mm tb
msd ignition
upper and lowers
subframes(short weld in's)
king cobra clutch
373 gears
pro stars w/ hoosier slicks. skinnies up front
a9P ecu, car always nos backfires with the a9L. without the spray, you cant tell the difference....
+125 shot.
consistent 11.0x's and has dipped into the high 10.90's at 125ish in cool air. full weight/interior 88gt. never been on a dyno either for tuning.
Discussion Starter · #7 ·
That's exactly my setup and what I am wanting to do as far as times, my car is a 94GT, I think .577 lift is a little to much for a 94 computer but I would love those kind of times so I might give it a try!
