1 - 13 of 13 Posts
Finally got me 100 shot added to the GT. I don't have DR's or slicks so my only hope was getting traction from the Sumitomo street tires. I couldn't spray in 1st gear since I looked like I was doing a burnout contest so I didn't hit the arming switch until the exact moment I dropped into second gear.
Spraying just from second gear here's what I netted:
60ft: 2.13
1/8: 8.65 @ 86 (lousy ET but good mph)
1/4: 13.12 @ 110
I need something to compare to for you nitrous users. Both with street tires or upgraded. My N/A run last nite was [email protected] (personal best is [email protected]).
Where do I stand on the "you suck" or the "good run" charts? ;)
I just made a few more passes on my 125hp dry NOS 5171 kit the other night. I was running [email protected] on the motor. I turned the spray on and I made a [email protected] pass and a [email protected] pass. That is with the spray coming on at 3000rpm in first gear which is right about the 60' marker(note that I have an auto.) One of these days I'll be able to afford a stall converter and launch on the spray to some NICE 60' times:D
Mike
344hp/482tq N2O
DAAAAAAMMMMNNNNN madmike, the tq on the spray is insane !!!!!
I've never dynoed mine.
Are you guys squeezing in 1'st gear? Even with 4.10's?
Is there any other way:D And as soon as the 4.56's are in, I'll still be spraying in 1st.:joy:
Discussion Starter · #11 ·
By the looks of those 12 second times, I need some traction bad. My mph is great I think but the time just doesn't add up.
What RPM are you guys shifting at while spraying? Can I shift sooner than normal since the torque is tremendous down lower in the rpm?? Please help on shift points!
I let mine shift itself(auto:D) I'm gonna have to get Randy to tweak my rev limiter and move it up just a hair. The engine revs so fast on the spray that I was actually hitting the limiter for an instant on the two shifts. In other words, mine shifts on it's own at 6k!
Mike
1 - 13 of 13 Posts
