im making a custom wiring harness basically and i need a male and female end of the connector, not just one side.
The problem is, there are about 30-40 wires, so if i have to use 2 20 pin connectors, or like 3 15 pin connectors then i guess i will if i have to.
The connectors need to fit thru a 1" hole, i figure if its a 2 row connector (like in the picture below) then it will fit thru it sideways.
Also, the wires being used are 16 and 14 gauge wires, so it cant be a cheap connector with tiny pins
anyone have any idea where i can get something like this?
(this is somewhat of an idea of what i need, except more wires, and both ends of the connector)
