First I know there a bunch load of treads out there on this. But I'm going to start my own. I will post pictures of the car and engine. I bought an 03/04 complete engine with engine harness only. Got all the hoses, intercooler pump. Heat exchanger. All the front accessories. Then I have a complete running and driving 96 Mystic cobra. I'm going return style. So that is cover. My biggest question is wiring. I only got the engine harness off the 03 cobra. I can't get anymore due to someone else buying everything else.
I heard and look at some builds. That people use their 96-98 engine harness. With that said. What are some connectors do I need to extend, add or delete? Also i need the tuner to shut off pats. This is my first mod car. I. Used to sbf pushrod engines. I done couple 351w swaps in fox and sn95 cars. Also if I keep the 96 ecu(which I want to do). Does a Sct livewire shut off pats? Or should I do a SCT chip?
