My shifter handle starts vibrating like hell in 2, 3, 4 starting around 4000rpm when I'm really romping on it...I had my trans rebuilt by the owner of a very well known trans shop in my area, and asked him about this. He said that it was most likely mounts that needed to be changed. I can't remember if it did this before the trans rebuild.
Should I buy stock replacement convertable mounts from ford?
I have a 91 gt vert
I assume you're talking about motor mounts? If so, then yes, the stock convertible motor mounts from Ford are just what you need. You might also want to check your tranny mount and the crossmember bushings while you're under there.
Absolutely, if your car sees winter weather there is a good chance that the crossmember bushings are rotted out.
