I've got a Holley 600 with vaccum secondaries on my 66 stang that has a 302 in it. It has ran fine for about 5 years....until yesterday. My car started "missing" at high rpm, and at idle it's missing so bad, the motor is shaking violently. I'm assuming it's a fuel problem.
Here's what I've done:
1) Checked the fuel filter...it's fine.
2) Checked the float levels, and the front bowl was full to the top. So, I took off the front bowl, checked the needle and seat, reset the float level and put it back on. It was still filling to the top, so I removed and reset the rear float level too. The fuel level seems to be fine now in the front and rear bowls.
3) I put new plugs in it because I thought since it was running rich that I had fouled a couple of them. The plugs looked fine, but I replaced them anyways.
4) I am getting spark to all 8 cylinders.
I have a Mallory Unilite distributor as well. I bumped up the idle on the carb and it will idle a little better, but when I tach it up it starts popping out of the exhaust and it feels like it's only running on 5 or 6 cylinders.
WTF is wrong????? Anyone? This carb was bought brand new 5 years ago and has only about 1500 miles on it. Thanks.
