just swapped out engines and my new one has the stage 2 cam in it. and i got her running, but my problem is my vacume. there is hardly any. i have a vac gauge and its reading 5inches of vac.
my question to you other corralers is have you had this problem and if so how did you fix it? did you get a pump and canister or what?
need the help and thanks to anyone.
I installed the cam in a built motor and although I never checked the vac the brake pedal was hard at idle (850rpm) so it was seeing 10psi+, are you sure it was installed correctly or you don't have a leak somewhere.
whats the lsa on the cam, if ne of u run a sd car you will have problems if the lsa is a narrow curve leading to lower manifold vaccum
