Black and green wires. With key on, engine off, the voltage should read <1.0 volts. It should be around .96, for the best performance. You can use the idle "set" screw to adjust it, or you can loosen the phillips screws on the TPS and twist it. If you can't get enough movement, you have to remove the TPS and bore out the holes..
--Ed
