I need to sell my old fuel injectors....I'm pretty sure they are 24lb but I need to double check with you guys...
They are from a stock 98 Firehawk with the LT1
I was told they are 24lbers....ran them with the 24lb sample tube and all was well....
is this correct or wrong?
Thanks guys
ops my bad...I know it is an LT1...so 97....I know it was the last year of the LT1 in f-bods
Thanks guys
Its hard to compare injector flow ratings for Ford and GM. GMs use a higher fuel line pressure than a Ford so therefore the same injector on a GM is going to flow a little more. I would guess an injector rated at 24lb on a GM would flow around 20 on a Ford. I replaced my old stock 19lb injectors on my 1990 LX 5.0 with some from stock a 2000 Z28 LS1 car. I didn't change anything else, they work fine, and I think they are rated at like 24lb on the LS1.
