Ok, My mods are in my sig. But othe rthan that, I have 24lb injectors, 75mm Pro-M MAF, 70mm T/B, I have fuel psi set at 30 psi, TPS is adjusted to around .90, and I need to know how to lean out my motor.
Is there anything that I could do with the MAF, such as blocking off part of the hole which samples the air, or anything else??
Would an air adjuster, from Dugan Racing, help me out a lot with this problem??
Thanks a Lot,
i have the smae problem! real badly
