Need Help!! Finished Bullitt intake install and having alternator problems
I think my problem might be with my PAPerformance plug.
In the picture below you will see a light grey plug not pluged in.
Do I need to plug this in anywhere.
Problem is car battery will not charge.
Discussion Starter · #2 ·
Anybody.
I know many of you have done a Bullitt intake install and have used the PAPerformance plug.
I know I have some problem with me charging system.
I can fully charge battery, place volt meter on battery, start car and watch voltage go down very slowly. If I rev the engine at all it will go down a little quicker.
I think that wire is internal in the cobra/bullit alt. so its not needed. Both small wires should have battery voltage when the key is on and when the engine is running.
Discussion Starter · #4 ·
What belt are you sposted to use.
THe GT belt fits but it a little tighter then stock was.
Dude, What alternator are you using? I used the Cobra alternator and PA plug and didn't have the "extra plug" so I am not sure. Like fastback brian said I don't think it is needed but we could be wrong, since your system isn't charging. Have you asked PA performance about it? later Ron
Discussion Starter · #7 ·
I ended up cutting the stock plug and also the plug that goes into that. Then soldering then together and then cutting that extra plug off.
All is perfect now.
Thanks everyone
