OK,
My brother has a 94 GT AOD-E, I used to be a ford guy but got out of it for a better car. Just kidding!
Here's the problem, at around 100MPH there is a NASTY:barf: vibration. Yesterday the drive shaft decided to throw the tranny seal out and it was sitting on the yoke, and the fluid is now turned into undercoating. After replacing the seal and taking it for a test-drive it happened again. Is this the d-shafts fault or has anyone else had this problem and if so what the f**k caused it.
did he iever have the DS out b4? if so then he might of put it in 180deg off..rotate it and check it again..where is it legal to go 100mph.. :) jk
NO
:lol:
Thanks for the help, anyone else have a suggestion or advise?
Banned
I'm guessing you have a bad u-joint. If you need to replace the u-joints just get an aluminum DS and be done with it.
Blown95GT,
It's good to see people from DE on a board, I guess I should have put in my location. I am in Brookhaven PA, it's just over the border on 95 and my brother is in Claymont DE. Anyway thanks for the advice.
