My 89 GT shifts great but I can not pull the shifter down to low. It feels like it needs to go down one more notch but acts like it is hitting a stop.Is there an adjustment or??
Thanks for any help.
Thanks for the help. Will try and locate it.
Discussion Starter · #5 ·
I haven't been shifting it manually ( I am 52 so not hot rodder) but I was just moving the lever and noticed it not going all the way down.
Go underneith the car.. loosen the bolt where there shifter cable attaches to the transmission shift lever... next get in the car and make sure the shifter is all the way in park and pushed fully against the forward stop. Next get under the car and push the transmission shift lever and make sure it is fully engaged in park and then tighten the shifter cable back down... It sounds like your detents of the transmission and the detents on the shifter are just slightly off...
Scott
Discussion Starter · #7 ·
Scott: Thanks and I will try that.
