Hi all,
I bought a KB 1500 for a 94-95 I was wondering what is the dfference between a blowzilla and the 1500? what does the flowzilla do and do i need one? what does the bypass do and will i need one of these?I plan to run around 9#. how much boost are they good for? What else am i gonna need to instal this blower? It comes with:
1500 Compressor
Front snout with length for 94-95
gt40-cobra style manifolds
Your pick of pulley size
front snout bracket
water neck.
I know i will need a GT-40 lower intake, intake elbow. will i need anything else? Do i just get a regular GT-40 lower? I already have a C&L CAI w/76mm MAF and aluminum intake pipe. will it bolt right up?
I plan on running a 255 high pressure intank pump
36# injectors and a adj. regulator.
I will be usning a MSD w/BTM running 13 degrees and pulling out 2 degrees for every pound of boost w/ the BTM
I will be using a DSS shortblock 9.3:1 compression ratio. AFR 185 heads, probably Steeda #19 cam. and all the other bolt ons. How much power do you think it will be making? I am shooting for 430RWHP.
Sorry for soo many questions but i was planning on a vortech. to much money for the KB and then i found this one used. Please tell me all you can
Shawn
1500 Compressor
front snout bracket
water neck.
Shawn
