I have the setup below and my compression is probably up around 10:1. Would it be safe for me to run N02 at all? I know for blowers you want the compression lower, but what about for N02?
Straight from the NOS website......
Q: Can high compression engines utilize nitrous oxide?
A: Absolutely. High or low compression ratios can work quite suitably with nitrous oxide provided the proper balance of nitrous oxide and fuel enrichment is maintained. NOS kits are used in applications from relatively low compression stock type motors to Pro Modifieds which often exceed 15 to 1. Generally, the higher the compression ratio, the more ignition retard, as well as higher octane fuel, is required. For more specific information talk to one of our technicians.
NOS website
Frank
