1 - 20 of 458 Posts
Going to start a build thread for the new motor build. At this point, got the engine pulled and going to start disassembly. I have already sold my blower setup, intercooler, blow off valve, and crank pulley. The plan is to go Trick Flow head, turbo cam, and 76mm turbo setup. Most likely will convert to E85 as well. I'll have a ton of questions and ask for input, so I'll just post everything in here. Hoping to start disassembly shortly!
Old setup:
Blower being taken off:
Motor pulled:
Hoping to start getting this thing broken down shortly. First step will be to get shortblock to machine shop just to go over everything, and at a minimum I will most likely swap to stainless steel piston rings. In a perfect world, that will be the only thing I end up changing with the short block. Currently have a '97 romeo block .20 over, Cobra crank, Manley 18cc Platinum Series pistons, Manley H-beam rods, and ARP 2000 hardware. My goals for this build is 750+rwhp through the auto. Any input/suggestions are welcome and I'll keep this thread updated with progress and any questions throughout the build so I'm not clogging up space. Just an fyi, I'm starting to list stuff that I will not be using in turbo build in the for sale section. I'll also be selling my MMR Stage 3 PI heads, custom grind blower cams, and Crower high lift spring setup. Would like to keep fully assembled!
As of now I'm leaning towards a CG Fab hot side, precision 7675, and not sure about cold side yet..possibly just open down pipe. Going to start with getting shortblock looked over than first thing will be deciding on which turbo cams for the TF heads
Pretty close to my build. I have a precision 76/75, CG fab headers/merge pipe, and custom piping for everything else. You will want the larger 44mm waste gate. I had a single 38, and I've had to add a 2nd gate as I was getting really bad boost creep when I stepped up from the MP70 to the precision 76/75. If you are going to E85 with the 18mm dish, you'll probably want 38cc heads. I have the 44cc heads, but running 11mm dish. What is your main goal for the car beside hp? Street, strip, or a little of both? You will definitely need to invest in a tubular K member, oil filter relocation set up, and you will also need to replumb the PS lines with AN style lines and fittings. Next big decision would be which trans, but that will depend also on what your plans are for the car. Make sure you get cams specific for the TFS heads. Good luck with the build!!
Sounds like a nasty build you have yourself there man. Got any pics you can post up?
- What size downpipe did you get from CG Fab? Are you running open downpipe or how did you plumb your exhaust?
- I was planning on the Tial 44 waste gate, so glad to hear you agree
- Again, due to either running E85 or VP100, I was also planning on going with the 38cc heads, which should put me right around 10:1
- This is mostly just a street beast, weekend warrior. Like to have some fun taking it out
- I am still researching which K member to go with, but I am definitely going tubular. Did you have to relocate your oil filter with CG's hotside? I didn't think that was necessary
- I was possibly thinking of completely ditching power steering and going with a FR manual rack, to help cleanup a lot of that junk
- I already have a built 4R70w and a PI triple disc converter from my blower setup. I'll have everything looked over just to make sure there are no issues before putting this back in with the turbo build.
- I am most likely going with either MHS or CMS TF head/cam package, which both of them are aware of the TF specific grinds
Thanks for all the input!
I was previously running an IW 10% overdrive crank pulley with my blower setup. I sold the 10% overdrive and was planning on getting stock diameter IW crank pulley with the turbo setup now. I previously had the internals balanced with my 10% crank pulley...should I have to get them rebalanced with the smaller regular diameter pulley now?
Wow big change coming!
Look forward to the updates to come!
Should be a beast!
Time will tell. I'm new to the turbo world so it's a whole new learning curve for sure
Thanks man, I'll try to post up updates as much as possible. Goal is to possibly have short block to machine shop by end of next week.
Gonna be FIRST CLASS! for sure. Did you ever figure out what was wrong with the motor or did I just miss it?
Not officially. I have it down to either piston ring or transmission. Should have answer shortly.
I was very happy with the CG fab kit for the most part. The only thing that was a surprise, was having to notch the passenger side frame rail. I run AC and PS, so if you are ditching those, might be a different story. Give them a call, they were great with helping me. If my motor has to come out, I have to drop it out the bottom, but I actually prefer to do it that way now that I've done it a couple of times. Keeps me from scratching up the paint in the engine bay. If you ditch the PS, you will also have to ditch the PB. If you are going to drive it a lot, I'd go ahead and keep them. The only things I used from CG fab were the headers and merge pipe. It came with a 3" starter pipe, and you might able to order it with a larger one but I didn't use it. I had my friends at Pusher Intake fab up all the other pipe work. I have a 4" downpipe with a small Vibrant "muffler." It routes down and ends just past the firewall at the toe board so I can run true street classes. It is super loud though, so you may want to factor in running a full exhaust if that concerns you. All the charge pipe is 3". I have a UPR K member, but any of the big names will work. I have a friend that's dealer for UPR, and can get pretty good prices if you are interested. You will need a run a remote oil filter for sure. I did a TH400 swap, but mine is pretty much a track car. The OD and lockup on the 4R will be better on the streets for sure. I ran CMS turbo 2.5 cams the first time around, but that was before all the findings of the issues with PI cams in TFS heads. New setup has custom L&M cams. Someone else might need to confirm this, but I'm pretty sure you can swap the balancer without needing to do anything. I'm pretty sure the balancers are "0" balance, not offset like some pushrod motors. Good luck, you will love it! My old setup with the MPT70 went 9.79 @140 on it's 3rd pass with no timing, no meth, and foot brake. Looking forward seeing what the new setup will do, hopefully I have time to get it finished soon.
Frame notch
Downpipe
Piping
Old setup with Edelbrock intake
New Setup
Two people above mentioned that a oil filter relocation is "needed" with CG Headers. I didn't need to with my CG headers and it was easy to get the filter in/out with no issues.
ks
ks
Yeah, could just be because mine is an older version is the reason I needed one.
Discussion Starter #15
Frame notch
Downpipe
Piping
New Setup
man, that is an absolutely beautiful setup. Thanks again for all the info, if you don't mind I'll probably be reaching out to you quite a bit for input as I go through the build here. I'm actually dropping my shortblock off @ L&M next Friday to start having them inspect internals and the bore. That manifold is absolutely a work of art that you have. Thanks again for all the info
Discussion Starter #16
ks
I guess it is hit or miss. I'll ask Caleb about it when I make the call to start the order to see lately if people have been having to relocate. A guy on another forum said there is currently a 4 week turnaround time for his kits :(
Good to see that he's staying busy but, ouch! Maybe use this time to plan/purchase the little things that you'll need. Are you going with the SS kit or mild steel? Which k-member will you use? I think his kits are designed around the UPR/QA1 units.
ks
Discussion Starter #18
ks
I'm leaning towards mild steel with a coating. And about 99% going with UPR k member setup, and looking up to see what's involved with a FR manual rack/brake setup as well.
Discussion Starter #19
Game plan is to have everything ripped apart down to the short block soon. Going to bring short block to L&M Race Engines next Friday to have them clean everything, check the bore, and start looking everything over. In a perfect world, I'll just need new bearings and piston rings, and the short block will be good to go. First thing up, I'm running a stock oil pan. Now would be the time to upgrade. I'm not normally a fan of MMR, but anybody running their 7 qt with windage tray? I'm only running a stock pan now with a stock 4v oil pump and a 15/16 pickup. Will I be able to use my same 15/16" pickup with this pan without any issues? Do you guys think the wind screen would be worth the extra coin? I also plan to upgrade my stock gears in the 4v pump to TSS billet gears
http://www.modularmotorsportsracing....roducts_id=309
Discussion Starter #20
Got a lot done tonight. Just about ready to bring to machine shop, planning on bringing next Friday. Everything looks like brand new, perfect condition. One cylinder has an extremely minor score to the wall, which I don't think is anything. Thinking transmission might have been my issue this whole time.
Maybe a little something going on here, but I doubt it:
About ready for machine shop:
I'm posting up some sweet heads/cams/valve spring setup for sale if anybody is interested!
There are some good memorial day sales going on this weekend. Think I'm going to pull the trigger on MMR oil pan with windage tray, 4v TSS billet gears for my oil pump, and stock diameter IW crank pulley
1 - 20 of 458 Posts
