ok i have a sn95 elec. fan on full blast, but if im in traffic with the air on the water temp will just keep rising. why does it do this. can i help it?
You could have a bad thermostat, I'd replace it and check your collant. You could also add some water wetter additive to your coolant.
no therm. is pretty new, just changed coolant, and i have a 3 core rad.
it only happens when the air is on. if its off perfect
hmmmmm??????
