Hi everyone, I am currently in the middle of building my first stroker motor. I have the block off to the machine shop and I am ordering my kit but I have never driven a 331 stroker nor have I ever been in a 331 stroker. I have been in a 347 stroker and i know they are similar but I don't know the specifics of his build.
I tried looking for a post that is close to what i am asking and i found some but not exactly. I have noticed everyone says to build the stroker for what you want out of it. Well I have done some research on parts and I have put together the main components for the build but I want your opinions on if these components work well together!?!? Thanks in advanced for your time!
I will be using this engine to put into a classic 62 ford pickup that i will be using just for weekends and hit the strip a couple times a year.
-Block: 1997 Explorer 5.0
-331 Kit: Scat Street/Strip 331, flat top wiseco forged pistons, scat crank 3.250, 4.030 bore, scat I-beam rods
-CAM: custom hydraulic Roller Cam from ADP (Brian)
-Heads: AFR SBF 185 (600 or 640 lift??, 58cc or 72cc chamber size?? what are the benefits and disadvantages of these??)
-Intake: Edlebrock RPM Air-Gap (im going carbureted not EFI)
-Carb: Holley Street HP 650CFM
let me know what your thoughts are please and any advise on any changes you would make.
I do not want to supercharge or turbo it yet at this point. maybe down the road.
Thanks,
Corey
Thanks,
Corey
