T-5 gearboxes do not have synchros on the reverse gear. Nothing to worry about to much. Putting it in 5th, then into reverse just lines up the teeth on the gears.
A properly adjusted clutch won't grind at all, or grinds very little.
yeah your clutch needs adjusted. it shouldnt grind or be hard at all to go into reverse
